Hi Mpho Manana,
I understand how inconvenient this is, especially when the sound icon shows an X and Windows says there is no audio output device. At this point, I recommend that you review and try the steps provided in the AI generated answer on your thread. That reply typically include the most relevant checks for this scenario.
To narrow this down, could you please let us know:
- Did this start after a Windows update, driver update, or any recent change to the laptop?
- What is the exact laptop brand/model and Windows version?
- In Device Manager, do you see anything listed under Sound, video and game controllers?
- Do you see any yellow warning icon or error code on the audio device?
- Are you trying to use the built-in speakers, wired headphones, Bluetooth audio, or an HDMI/external monitor audio output?
In addition to the troubleshooting steps already suggested, you can also try checking whether the audio services are running:
- Press Win + R, type
services.msc, and press Enter.
- Find Windows Audio and Windows Audio Endpoint Builder.
- Make sure both services are running and set to Automatic.
- If either service is stopped, right-click it and choose Start or Restart.
If Device Manager does not show any audio device at all, please also try this:
- Open Device Manager.
- Select View > Show hidden devices.
- Select Action > Scan for hardware changes.
- Restart the laptop and check whether the audio device appears again.
If the audio device still does not appear, the next best step would be to install the latest audio driver directly from the laptop manufacturer’s support website for your exact model.
While my initial response may not fully resolve the issue, I truly appreciate your cooperation as we work together toward identifying the most effective solution. Thank you so much for your understanding.
